Activity Forums Apple Final Cut Pro Movie files not showing up in Event Library
  • Movie files not showing up in Event Library
    Posted by Oren Hercz on June 5, 2012 at 1:55 pm
    Hi FCPXers,
    Just made the switch and am liking it, only I’m having a problem where movie files aren’t showing up in my Events Library. If I go into the finder I see the files are there in the Event folder with their unique identifiers and all that, but then in the Event in the FCPX GUI they are missing. Even, if I go to relink media, it finds all the files and says 76 files found, but then once it relinks everything and I go back to the Event Library, only 41 files are visible. The remaining files are still missing. If I drag these files from the finder onto the event same thing. They just won’t show up!
    I can even drag the clip from the finder onto my project and it will play, but if I try to reveal in Event Library, it won’t find it.
    Any thoughts?
    Oren
    Oren Hercz replied 14 years, 3 months ago 2 Members · 2 Replies
  • Andy Neil
    June 5, 2012 at 2:27 pm
    It sounds as though you have some kind of filtering going on in the event browser. Look at the top of the event browser window. There is a drop down. Choose All Clips from the menu in order to see all clips regardless of favorited/rejected status, keywords, etc.
    Andy
    https://www.timesavertutorials.com
  • Oren Hercz
    June 5, 2012 at 2:39 pm
    Hey thanks,
    That wasn’t the problem, but it gave me the idea of what was. I was viewing “all clips,” but I had a filter applied from the event search bar. It’s pretty easy to miss, though, because all you see in the search bar is a little dark “key” logo!
    Thanks again,
    Oren
