Movie file format and size
Posted by Phil Vk on April 3, 2006 at 11:11 amI am very new to Sony Vegas. I recently captured about an hours worth of DVC film which was saved on my hard drive as multiple .avi files, some very large. I dragged one of the clips to the editing area, split it, and added some text. Using the movie wizard, I created a Quick Time .mov file. This file was over 7 Gigs for only about a minute
Edward Troxel replied 20 years, 6 months ago 3 Members · 7 Replies -
Edward Troxel
April 3, 2006 at 2:38 pmFirst of all, I don’t think Vegas does a great job with MOV and always use WMV. However, it sounds like you rendered to an uncompressed MOV file. MOV is just a wrapper – you also have to pick the amount of compression and the codec used. 7Gig for 1 minute sounds a little extreme, though – uncompressed should be closer to 1 Gig/minute.
Phil Vk
April 3, 2006 at 2:54 pmI did not see any choices for compression when I was using the make a movie wizard. Can you give me a clue where I should look for these settings?
Phil -
Edward Troxel
April 3, 2006 at 6:17 pm -
Phil Vk
April 3, 2006 at 9:03 pmI found quality settings under File > Properties and set the Video to “Preview”. Is this how the compression you referred to is handled? You also said you are not familiar with Sony Vegas. Isn’t this a Sony Vegas forum?
Phil
Terry Esslinger
April 3, 2006 at 10:58 pmEdward said he was not familiar with Studio which is the watered down version of Vegas and is what you apparently have. He is VERY familiar with the full fledged Vegas program!
Phil Vk
April 3, 2006 at 11:06 pmGood. Sorry for the misunderstanding….I thought I might be in the wrong froum.
Phil -
Edward Troxel
April 4, 2006 at 1:41 am
