Activity › Forums › Apple Final Cut Pro Legacy › movie file cannot be found..
  • movie file cannot be found..
    Posted by Ursula Sedunko on May 19, 2010 at 9:38 pm
    fcp can’t be executed properly because it cannot find a movie file. but: i can’t remember deleting any.. is there another possibility or am i deleting movie files while sleepwalking?
    thank you very much, us
    Steven Gonzales replied 16 years, 4 months ago 4 Members · 4 Replies
  • David Roth weiss
    May 19, 2010 at 10:25 pm
    Use the spotlight feature in the Find to try locating the file. If you can’t find it yourself, then FCP sure won’t be able to.
    Then, fix permissions on your system drive using Apple Disk Utility. It’s possible that the file became corrupted or that it’s permissions got corrupted, and that may fix the problem.
    Of course, you might have inadvertently deleted it by mistake, but that’s probably not the case.
    Also, try trashing preferences too if all else fails.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jeremy Garchow
    May 20, 2010 at 2:09 am
    Sounds like you imported a reference movie and something got deleted (like a render file).
  • Ursula Sedunko
    May 20, 2010 at 7:48 am
    I got WLAN here and store completed projects there. there was a problem with the raid, because windows and mac-users were accessing it and it doesn’t like that very much. some files got mixed up.
    file is gone, i had to do it again.
    anyways thanks a lot for your help, i’m quite surprised that this forum works so well.
    cheers, uschi
  • Steven Gonzales
    May 20, 2010 at 5:53 pm
    Could this be a Fat 32 format drive, and a 2 gB size limit issue? Sometimes the quicktime files will play off the Fat 32 drive, but when copied they are missing an auxiliary file, and report “no video” or something when imported to FCP.
