Activity Forums Apple Final Cut Pro Legacy Movement flicker
  • Movement flicker
    Posted by Jeff Loot on December 10, 2012 at 10:51 pm
    Hey guys,
    I just got the new imac and have found that in FCP 7 between cuts and some movement I am experiencing a flicker or a black frame, like it’s running from a slow drive. I’m not sure why this has only just started happening with the new comp? Or is it something else I have missed?
    Any help would be much appreciated, thanks!
    Lee Caldon replied 13 years, 6 months ago 3 Members · 4 Replies
  • Neil Patience
    December 11, 2012 at 4:52 am
    Hi Jeff
    Odd flickering and black frames on cuts is often a symptom of trying to edit directly with H264 or MP4 files.
    What format are you editing with ?
    best wishes
    Neil
    http://www.patience.tv
  • Jeff Loot
    December 12, 2012 at 2:35 pm
    Hi there!
    I’m cutting with ProRes. I was working exactly the same before on a slower MAC. Then I plugged the G-Raid drive into the new IMac, installed FCP7 and have these movement flickers. Could it be the monitor?
    thanks!
  • Neil Patience
    December 12, 2012 at 7:42 pm
    Hmm so if you are working on a previous project that was fine on the older MAC it does seem unlikely that anything has changed in terms of the media.
    I suppose it could potentially be a monitoring thing although I would have thought it was unlikely. Does it always occur in the same place or is it random ?
    Have you any other projects you can open and see if it happens there ? Does it only happen on this sequence or do you have any other sequences you can check ?
    If you export a section that is displaying the flickering does it show up on the exported file or is that OK ?
    Kinda hard to diagnose without seeing it really.
    Maybe worth doing the usual prefs trash and permissions repair just to eliminate the basics.
    https://www.digitalrebellion.com/prefman/ – this is the easiest way to trash prefs.
    best wishes
    Neil
  • Lee Caldon
    March 4, 2013 at 2:04 pm
    I’ve been experiencing exactly the same problem since upgrading to a new iMac a couple of weeks ago. The flicker is only in FCP7, not in the export. No flicker using the same FCP file on my early 2012 MacBook Pro.
