Activity Forums AJA Video Systems Moved Kona LHe Bay now no audio or machine control
  • Moved Kona LHe Bay now no audio or machine control
    Posted by Matt Kerstein on February 17, 2009 at 10:05 pm
    Aloha,
    We moved one of our Kona LHe edit bays to another desk and now we have no RS422 deck control or audio..or component video in from Betacam.When I change Sys Prefs to monitor audio thru Line out Mac in I get sound palying aiff’s off desktop but nothing thru FCP in either AJA or Mac line out. Tried re-seating board..notta..Any ideas?
    Matt Kerstein replied 17 years, 6 months ago 2 Members · 4 Replies
  • Matt Kerstein
    February 17, 2009 at 11:02 pm
    Talked to Promax (happy they have people there still for tech support)They asked if i have a green light on my breakout box. I do not…tried re-connecting fat aja control cable..nice firm connection..no pins bent or messy..still no green light..which why I assume I’m not getting correct signal flow.
    Aloha & Mahalo from Maui
  • Gary Adcock
    February 18, 2009 at 2:55 pm
    [Matt Kerstein] “They asked if i have a green light on my breakout box. I do not…tried re-connecting fat aja control cable..nice firm connection..no pins bent or messy..still no green light..which why I assume I’m not getting correct signal flow.”
    then it is possible you fried the board.
    but first
    did you install the correct drivers from the website for your system / FCP version ?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Gary Adcock
    February 18, 2009 at 2:57 pm
    [Matt Kerstein] “They asked if i have a green light on my breakout box.”
    check to make sure that the led is lit on the CARD – that is the one that counts- it should flash during startup.
    gary adcock
    Studio37
  • Matt Kerstein
    February 18, 2009 at 6:53 pm
    That multi pin control cable is not labeled what direction it should go.. So I swapped ends..presto..green light everything works 🙂
