Move Track to front while changing track motion
John Rofrano replied 11 years, 8 months ago 6 Members · 16 Replies
Roger Smith
December 30, 2014 at 6:03 pmBrilliant!! Thanks John. Here the solution I came up with. It’s quick and easy, but not uniform with the other cuts. I’ll run with it unless someone can point out a better way?
Solution to Second track on top
Aleksey Tarasov
December 30, 2014 at 6:09 pmHere’s demo project – work was done using Track Motion keyframes (changing Z position).
John Rofrano
December 30, 2014 at 10:09 pmThat looks fine and it’s a good compromise between a lot of editing or a little fading.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Russ Froze
January 1, 2015 at 12:56 am[Roger Smith] “I do several teams and lots of games, so the least amount of time I spend on each project helps the business. Nothing fancy..”
Hi all, sorry I’m late I’ve been away.
The easiest way is for me, is to add a track above and make all below a child. Then do track motion from the parent track. This avoids any further cutting or fading in and out. Sample veg is here 8357_movetracktofrontwhilechangingtrackmotion.veg.zip
Great fun and I find all the solutions are very clever and informative. Good work all.
Russ Froze -
John Rofrano
January 1, 2015 at 5:04 pm[Russ Froze] “The easiest way is for me, is to add a track above and make all below a child. Then do track motion from the parent track. This avoids any further cutting or fading in and out.”
The problem with that solution is you are just zooming into the entire frame which will reduce the resolution significantly and also doesn’t adjust for the fact that some videos are behind the other and need to come forward so that the entire video frame can be seen not just the section that’s visible from behind. The only way to get the entire frame to display is to bring the video forward in 3D space so that the whole video is revealed.
~jr
