Activity Forums Adobe After Effects Expressions Move parented animated property among time in child’s layers
  • Move parented animated property among time in child’s layers
    Posted by Lucas Daniele on April 1, 2019 at 4:42 pm
    Im having troubles making a inherited animation, start when layers appears in comp
    like this:
    Controller (animation of 1 second)
    ——-|>child animation start
    —————-|>child animation start
    ————————-|>child animation start
    ———————————|>child animation start
    How do i control this? is there a way with expressions?
    Tomas Bumbulevičius replied 7 years, 5 months ago 3 Members · 2 Replies
  • Vera Steinbeck
    April 1, 2019 at 9:37 pm
    i don’t completely get what you mean but this sounds a bit like value at time
    https://youtu.be/6TKEcTHdGK8?t=107
  • Tomas Bumbulevičius
    April 2, 2019 at 5:16 pm
    Hey Lucas,
    do you want these child layers to be incrementally delayed from its parent, or not necessarily? If thats the case, you could set delay and add it from one layer to another, by indexing them. In addition to this, you won’t need to actually move layer’s inPoints – instead, by starting at the same time of the comp, they could be still delayed incrementally. This is useful if you are not sure about the ‘timing’, and does not require manually changing in points.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
