Activity Forums Apple Final Cut Pro Legacy Move multiple clip using nesting
  • Move multiple clip using nesting
    Posted by Michael Allen on December 8, 2008 at 3:14 pm
    I want to move a number of clips relative to each other. I understand that I should nest those clips and then move the nest, however each time I do this I only am able to move only one clip in the nest. Can someone give me step by step instructions on exactly how to do this? I realize this should be simple but it is not working for me.
    Mike
    Aaron Wiebe replied 13 years, 9 months ago 6 Members · 14 Replies
  • 14 Replies
  • Shane Ross
    December 8, 2008 at 4:56 pm
    [Mike Allen] “I want to move a number of clips relative to each other. I understand that I should nest those clips and then move the nest,”
    I wouldn’t. You can drag a box around the clips and move them all at once. Or my favorite tool, TTTT (press T four times) and you will get a double arrow that points right. That will select all the clips from the point you click, and too the right. Then you can move everything where you want.
    Shane
  • David Roth weiss
    December 8, 2008 at 5:02 pm
    [Shane Ross] “Or my favorite tool, TTTT (press T four times) and you will get a double arrow that points right.”
    Or hit Shift + T, which does the same thing.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Tom Wolsky
    December 8, 2008 at 5:04 pm
    Not quite. Shift-T is the track height or some such. You press T then hold the Shift key to toggle it to the multitrack selection tool.
    But I don’t think that’s what Greg’s really looking for. It sounded like he wanted to select non-contiguous clips and group them keeping the spacing. Or maybe I was making it more complicated than it is.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • David Roth weiss
    December 8, 2008 at 5:31 pm
    [Tom Wolsky] “Not quite. Shift-T is the track height or some such.”
    You are absolutely correct Tom, my bad.
    The proper keyboard sequence is T, then hold down Shift, which indeed fires up the double right arrows.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael Allen
    December 8, 2008 at 7:02 pm
    “It sounded like he wanted to select non-contiguous clips and group them keeping the spacing. Or maybe I was making it more complicated than it is.”
    This is what I want to do. I want to use the motion tab and keyframes to move multiple items together. Will shift T do this?
  • Michael Allen
    December 8, 2008 at 7:09 pm
    I realize that I can highlight multiple clips and move them around, but I cannot use the motion tab to give the grouped clips a motion path in relation to one another. When I do this after nesting, only one clip moves on the motion path. I know that I do not have to figure the motion path one at a time. Also, If I copy and paste, all the clips sit on top of one another. This is not the desired outcome.
    Mike
  • Shane Ross
    December 8, 2008 at 7:30 pm
    [Mike Allen] “but I cannot use the motion tab to give the grouped clips a motion path in relation to one another.”
    PARENTING…that is something After Effects does. You can’t do that in FCP…sorry. Motion, yes. AE, yes. FCP…nope. It is an NLE, not compositing application.
    Shane
  • Michael Allen
    December 8, 2008 at 7:42 pm
    It is good to know that I cannot do this. However, your comment that “It is an NLE, not a compositing application.” is funny to me. There are many things that FCP now does that had to be done in a compositing application not too long ago. I did not know that this was not one of those things.
    Mike
  • Shane Ross
    December 8, 2008 at 7:51 pm
    Well, it can do some pretty good basic compositing, but not the advanced stuff like parenting.
    Shane
  • Michael Allen
    December 8, 2008 at 8:14 pm
    One way to accomplish this it seems is to export the clip through quicktime conversion as an animation file to keep the alpha channel. Then re-import the clip and apply motion. This will work, if one does not have an FX program I guess. I was thinking there might be a better solution.
    Mike
