Activity › Forums › Adobe After Effects Expressions › Move Layer on Angle
  • Move Layer on Angle
    Posted by Mark Walczak on November 12, 2014 at 4:53 pm
    Hi everyone,
    I’m sure Dan knows the immediate answer to this, but just in case someone wants to try beating him to the punch, here’s what I’m trying to achieve:
    I need a simple way of moving a layer on an angle. Essentially, I’d like to have two sliders on a footage layer: one for X-position, and one for angle. As I set keyframes and animate the X-position of a layer, I would like the Y-position to automatically increase/decrease in a way that makes the layer appear to be sliding on the defined angle. I’ve tried rigging my own solution by using the tangent of a given angle, but that didn’t seem to work.
    Any and all help would be appreciated.
    Thank you!
    https://vimeo.com/explosivegraffix
    Prakash Gaygaye replied 11 years, 10 months ago 3 Members · 4 Replies
  • Dan Ebberts
    November 12, 2014 at 7:25 pm
    Will you be animating the angle? If so, that’s a much more complicated expression because you’ll need to calculate where the layer was at each of the previous keyframes.
    Dan
  • Mark Walczak
    November 12, 2014 at 7:43 pm
    Hi Dan,
    No, it would be great for the angle to be constant. No animation needed 🙂
    Thank you!
  • Dan Ebberts
    November 12, 2014 at 8:32 pm
    Play around with this and see if it’s close:
    x = effect(“x”)(“Slider”);
    a = effect(“angle”)(“Slider”);
    y = -x*Math.tan(degreesToRadians(a));
    value + [x,y]
    Dan
  • Prakash Gaygaye
    November 12, 2014 at 11:31 pm
    bounce
    prakash123
