Activity Forums Adobe After Effects Expressions Move from position to position by x and then y
  • Move from position to position by x and then y
    Posted by Peter Menich on January 5, 2015 at 5:46 pm
    Hey All,
    I’m trying to cook an expression where a layer will move around the comp to a number of keyframed positions, but rather than move ‘as the crow flies’ it moves first in the x dimension and then the y.
    I’ve been looking at the ‘nearestKey’ command and ‘.key’, but I can’t quite figure it out.
    I thought maybe you could treat each move as a right angled triangle, where the direct move is the hypotenuse and then you could use trig to figure out the x and y… but again, my brain has failed me.
    It doesn’t help that it’s my first day back after christmas either!
    Any pointers will be greatly appreciated.
    P
    Peter Menich replied 11 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 5, 2015 at 6:25 pm
    Try this:
    v = value;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time) n--;
    if ((n > 0) && (n < numKeys)){
    t = time - key(n).time;
    dt = key(n+1).time-key(n).time;
    if (t < dt/2){
    v = linear(t,0,dt/2,key(n).value,[key(n+1).value[0],key(n).value[1]]);
    }else{
    v = linear(t,dt/2,dt,[key(n+1).value[0],key(n).value[1]],key(n+1).value);
    v
    Dan
  • Peter Menich
    January 5, 2015 at 7:45 pm
    Dan, You nailed it again!
    Awesome.
    Many thanks.
    Pete
