Activity Forums Apple Final Cut Pro Legacy move forward 1 FIELD
  • Jerry Hofmann
    November 15, 2009 at 12:27 pm
    No you can’t, but you can see both fields externally, or when you set your canvas or viewer to be 100% size.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Andy Mees
    No … you can’t step through field by field in FCP.
  • Neil Sadwelkar
    November 15, 2009 at 3:44 pm
    Or, if you need to examine fields, you could put the shift fields filter and toggle upper or lower to see each field.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Andy Mees
    November 15, 2009 at 3:49 pm
    Or cut with an NLE that does allow you step through field by field.
  • Peter Wiggins
    November 16, 2009 at 12:43 am
    Or Shake
  • Massimo Croce
    November 17, 2009 at 9:28 am
    or After effects
