Activity › Forums › Adobe Premiere Pro › Move clip with exact amount of seconds through timecode field
  • Move clip with exact amount of seconds through timecode field
    Posted by Allard Depallerd on March 6, 2018 at 10:13 am
    Hi guys..
    I know I can use the timecode field in CC to move my playhead an specific amount of seconds on my timeline.
    So if I type +31.00… it will move my playhead on my timeline 31 seconds later…
    My question is.. Can I do this same technique with a clip selected, so that it moves the clip automatically 31 seconds? (or whatever time i want) (so not just the playhead, but the selected clip (s) aswell.
    I think I did this once by accident.. and it would be a usefull feature for my work…
    thanks!
    Allard Depallerd replied 8 years, 6 months ago 3 Members · 6 Replies
  • Tero Ahlfors
    March 6, 2018 at 10:15 am
    If you have clips selected they will be moved instead of the playhead.
  • Allard Depallerd
    March 6, 2018 at 10:45 am
    Thank you for your reply
    I must be doing something wrong.. when I select a clip and add some seconds in the timecode window… it’s still the playhead that moves and not the clip…
  • Jon Doughtie
    March 6, 2018 at 6:30 pm
    Are you using “+” or “-” modifiers in front of the time entry?
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2017.1 (as of 8/2017)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from UHD MP4, HD MP4, and HD P2 MXF.
  • Allard Depallerd
    March 7, 2018 at 9:32 am
    Yes I am…
    I select the clip, then I click in the timecode field, and type something like +31.00
    And then just my playhead moves..not the clip…
  • Tero Ahlfors
    March 7, 2018 at 10:23 am
    [Allard DePallerd] “I select the clip, then I click in the timecode field, and type something like +31.00”
    When you click the timecode field you’re entering the timecode. Instead of that select the clip, press numpad +, enter the value, press enter.
  • Allard Depallerd
    March 7, 2018 at 10:54 am
    Ahhhh so that’s what i was doing wrong… I clicked the timecode box first…
    Thank you very much for helping me out..problem solved!
    regards, Allard
