Activity › Forums › Maxon Cinema 4D › Move Camera
  • Move Camera
    Posted by Ben Shelock on July 15, 2009 at 4:51 pm
    Im just starting out with Cinema 4d and I’m stuck by something which should be the most simple.
    How do I move the camera? I dont mean in animation, just for when you’re editing and want to see the other side of an object or something.
    Elio Willy replied 8 years, 1 month ago 3 Members · 3 Replies
  • Adam Trachtenberg
    July 15, 2009 at 6:29 pm
    There are three icons at the top-right of the viewport that you can click-drag for pan/zoom/rotate, or you can use the 1,2,3 hotkeys. Might want to check out the help docs, too. 😉
  • Ben Shelock
    July 15, 2009 at 6:32 pm
    Thank you! I always get stumpped by the bit that should be the most simple.
  • Elio Willy
    August 16, 2018 at 2:58 pm
    Hold down alt key
