Activity › Forums › VEGAS Pro › move audio tracks to the bottom of timeline
  • move audio tracks to the bottom of timeline
    Posted by chris scott on July 3, 2022 at 7:26 pm
    Hello all,
    I have vegas 14 now and although I like the separate audio for each track it make my timeline very tall. How can I move them to the bottom of the timeline. While working with clips, I dislike it beneath each individual video while editing.
    Steve Rhoden replied 4 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • John Bolton
    July 4, 2022 at 2:48 pm
    Ungroup the Audio from the Video and then Grab the Header of the audio track and drag it down to where you want it
  • Francois Pénzes
    July 4, 2022 at 9:01 pm
    Hi Chris
    Just to add to John’s reply, I too separate my video tracks from my audio tracks and put them at the bottom. Make sure to label them clearly !!! ( I fired up my old Version 12 to show what it would look like)
  • Edward Troxel
    July 5, 2022 at 2:21 pm
    You don’t have to ungroup them before moving the audio tracks. Just grab the audio track header and drag it down.
  • chris scott
    July 7, 2022 at 6:12 pm
    Thank you for the replies and I can easily drag the audio to the bottom, Only problem is if i add another clip it again adds the audio in its separate track.
    Maybe to ask another way, If i have video track 1,2,3&4. I would like to have Audio track 1,2,3&4 but at the bottom. If i drop in a new clip in track 2 I would like it to add to audio 2 that is currently the second down audio track. (6th from the top) 4 vid/4aud.
    I can drag it each time and it works, just wish i could somehow sync them when needed and un-sync them when not.
  • Francois Pénzes
    July 9, 2022 at 3:09 am
    Hi Chris
    The following example is what I understand from your explanation. It may not be what you’re looking for but it may be the gist of it. You can extrapolate from it.
    1- Just select the required tracks by holding the Ctrl on the keyboard. No need to Un-group if you don’t need to.
    2-Drag tracks to where needed (black line is your reference)
    3-This is what it will look like.
    As far has I know, the only way to insert a video without the audio track would be to separate the video and audio tracks before inserting them. I don’t know an other way. Maybe someone else does.
    Cheers !
  • Edward Troxel
    July 11, 2022 at 2:18 pm
    Vegas just doesn’t work that way. Premiere does – but that’s a different timeline paradigm. Vegas keeps the video/audio together. Yes, you can then move it to another track but it doesn’t do what you’re requesting automatically.
    I suppose you could write a script that would do that for you. Then you’d have to add all new files using the script.
  • Steve Rhoden
    August 29, 2022 at 12:54 pm
    Sorry Chris, it all has to be manually dragged to where you want it….. In the meantime, you sure you don’t wanna upgrade to a more recent Vegas version?
    Man Edward, that must would be a very complex script to write. Only you and Waag i know could pull that off, lol
