Activity › Forums › Adobe Illustrator › Move anchor point in illustrator
Crystal Jackson replied 11 years, 2 months ago 14 Members · 14 Replies
Sushma Sukumaran
September 6, 2012 at 5:57 amwhy dont you try clicking the anchor point with the pen tool and press shift+ desired arrow keys to shift the arrows..
Ignacio Carrera
September 22, 2013 at 4:34 amTo move an anchor point you need to use the direct selection tool, the light grey arrow below the black arrow
Crystal Jackson
July 7, 2015 at 8:47 pmI found that if I needed to move an anchor point, I click on the Convert Anchor Point Tool (Shift + C on a PC) and PRESS on the point I want to move while I hold down the SPACE bar.
This will make your line look like rubber bands that are stretched out from on point to the next,then I would simply double click on the anchor using the Convert Anchor Point Tool, and bend the line with the handles.
Hope this helps someone.
Crystal J
