Activity Forums Adobe Illustrator Move anchor point in illustrator
  • Move anchor point in illustrator
    Posted by Joakim Åberg on October 4, 2008 at 4:08 pm
    I´ve used photoshop for several years and tried illustrator today, and I cant move anchor points by pressing ctrl while using the pen tool. I only move the entire spline. How can I move one point?
    Crystal Jackson replied 11 years, 2 months ago 14 Members · 14 Replies
  • 14 Replies
  • Kelly Johnson
    October 5, 2008 at 2:15 pm
    I don’t think you can actually move the point along the path. What you can do is to use the pen tool with the + symbol. click where you want the new point to be and then use the pen with the – symbol to remove the original point.
    Maybe someone knows something else but I’ve never heard of moving a point along a path (spline)…for the app to dynamically calculate the math for such an operation would seem a little processor intensive?!
  • Vincent Rosati
    October 5, 2008 at 9:55 pm
    I only know how to move a center-point during a ‘Rotate’ operation.
    Select the object.
    Press ‘R’ to activate the Rotate tool.
    Than, left-click on the rotate point to drag it.
    https://library.creativecow.net/articles/rosati_vincent/radial_patterns.php
    Maybe you could group an empty object beneath your main object, that has a point in the location you desire.
    Vince
  • Bob Nigel
    January 25, 2009 at 9:59 am
    Using the warp tool i was abel to move anchor points click warp tool and the click and drag the anchor point to were you want it to be.
    Ps i made this stupid account just so i can try help
  • Bob Nigel
    January 25, 2009 at 10:07 am
    Click on the pen tool and hold it there till you get the 4 different pen tools. select the convert anchor pen tool or Shift C for the tool click on the anchor point once then use the arrow keys on your keyboard to move them. Just figured this out now
    good luck
  • Ed Crossland
    April 18, 2009 at 10:33 am
    If you make a simple click and hold on the anchor point while in “convert anchor point” mode (see last post) you are able to move the handles associated with that anchor point. If you shift+click and hold you will be able to move the anchor point with the mouse (strangely, you will then need to release shift while holding the mouse click or you will be restricted to 45°, horizontal and vertical direction movement)
  • Jinn Jackson
    May 1, 2009 at 9:34 am
    I think, well maybe someone knows something else but I’ve never heard of moving a point along a path (spline)…for the app to dynamically calculate the math for such operation would seem a little processor intensive?
  • Ray Northway
    May 31, 2009 at 1:55 am
    in illustrator, use the “direct selection tool” (the rightmost arrow at the top of the toolbar, appears ‘white’ rather than ‘black’), hold the pointer over the anchor until you see a hollow square nest to the point (not the solid square), then click and drag at will.
    I was searching for this answer when I found this thread. Unhappy with any of the ‘workarounds’ here, I just started playing, and figured this out.
    works great.
    have fun!
    Ray
  • David Matthews
    April 9, 2010 at 6:22 am
    quick correction to the above: you must double-click the anchor point of interest using the Direct Selection Tool (white arrow), not just hold your cursor over it.
  • Kelly Jervis
    March 15, 2011 at 12:21 am
    Thanks it worked!!!!!!!!I have been using Vector Diary to teach myself illustrator and am told to use pen+ Cnrl +select anchor to move just point around it only works sometimes other times moves entire shape,have spent days trying to find out what I am doing wrong,I am a photoshop user and just keep thinking I should stay that way………..
  • Ally Oslinn
    October 7, 2011 at 3:11 pm
    while in “convert anchor mode” hold down shift then the letter “z” to move one point!
