  • Posted by Marcel Laverdet on October 18, 2007 at 11:11 am
    well, it’s a very very beginner question, but… I’ve done the first tutorial, and if I get easily the different way to get a path, or a motion of the emitters, the simple way to move them is indecipoherable!… the help say: just drag it… ok, I load the emitter in the center of the satge, then at frame 1 of the movie I want it to be at the right corner, and follow, with orientation, the space ship.. and if I “drag” that damned emitter, it’s just another one which comes on… thank you for help!!!!!
    John Holste replied 18 years, 11 months ago 3 Members · 2 Replies
  • Alan Lorence
    October 18, 2007 at 11:25 am
    Make sure you’re in “Select” mode, not “Add” mode. Press “A” to toggle or use toolbar button. When in “Add” mode, all clicks add a new emitter.
    Alan.
    http://www.wondertouch.com
  • John Holste
    October 18, 2007 at 11:29 am
    I had the same issue when I first started using pI, until I realized there are two modes add and select. There is an arrow in the tool bar, if the arrow is not pressed your cursor is a circle dot, add emitter mode, if the arrow is pressed your cursor is an arrow, select emitter mode. Select emitter mode is where you can move the emitter; you can also do a R-click on the emitter and “record position”.
    John
    P.S. I had to do the tutorials a couple of time before I got it!
