mov to m4v best quality low file size for mac
Hey guys,
Any suggestions on programs I could buy that could produce great conversion to an m4v (h264) with customizable settings since I need my output in 640 x 360 format. I like usung Apple Compressor as it produces great quality and you can change the settings to your likings. The only problem with that is they set the limit to 1000kbps as the minimum. That is a disadvantage to since I produce videos for web use. I used to do fine with flv but since mobile site was launched I need it to be iphone-ipad friendly. For flv I use 448kbps and the quality is good enough but when I convert it in AVS with the same bitrate the quality drops a lot. And I need to reboot to Windows too to get to AVS just for this. So any AVS for mac out there with better encoding skills is highly appreciated. Im willing to buy if its a good software.
