Activity Forums VEGAS Pro .MOV Problems
  • .MOV Problems
    Posted by Mack Grenfell on September 16, 2010 at 6:28 pm
    Ok so I’ve been having some rather strange problems with .mov files. Whenever i try to interact with them, they seem to crash my computer one way or another. I’ve heard this was to do with quicktime and so I followed the general consensus of installing quicktime 7.1.6 which apparently would fix the problem, it’s only that it hasn’t. I wasn’t sure which forum to post this in but seeing as the only time I ever need to use .mov files is with vegas…
    I’m on Vista if that’s of any help by the way. Many thanks..
    John Rofrano replied 16 years ago 2 Members · 5 Replies
  • John Rofrano
    September 16, 2010 at 10:57 pm
    I’m not sure where you read that but 7.6.2 is the safest version to use with older versions of Vegas. Vegas Pro 9.0e and Movie Studio HD 10 have no problems with the latest Quicktime. Make sure whatever version of Vegas you have that it is up to date.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mack Grenfell
    September 17, 2010 at 10:40 pm
    So far so good, if it continues to work you may consider yourself my new childhood hero. Thanks 🙂
  • John Rofrano
    September 18, 2010 at 3:28 pm
  • Mack Grenfell
    September 19, 2010 at 7:38 pm
    Oh mighty John, I’m yet again in need of your services. Whenever i import an .mov video into Vegas, there’s a lot of loading and waiting around and if I click or try to do anything during this loading period, my computer instantaneously crashes. I used to be able to import just fine and dandy but it seems like every time I try, it crashes; regardless of whether I click/do anything or not. Do you have any suggestions? Is it my computer that’s the problem? And finally, could you recommend any lossless .mov converters for me?
    Many thanks..
  • John Rofrano
    September 19, 2010 at 10:57 pm
    Hmmm… what codec do the MOV files use? In the Quicktime player, press Ctrl+I to bring up the Inspector and it will tell you. I assume you are using Quicktime 7.6.2? What version of Vegas?
    ~jr
