Activity Forums Adobe Premiere Pro .MOV only imports as audio :(
  • .MOV only imports as audio :(
    Posted by Sem Offat on December 15, 2014 at 8:49 pm
    Someone posted this exact problem, but then they switched to a different editor and problem was fixed. So no suggestions were made!
    I’m using Premiere Pro CC and have edited .mov before, without trouble. This time, someone else shot the footage (Panasonic AF100, 1080 p 60i) (Apple ProRez 422). The footage imports only as audio.
    Also there is interlacing problems, but I won’t know for sure if I can fix those until I can actually SEE the original footage. If I convert the footage to MP4 I can see it and mostly (?) solve the interlacing problem.
    Any suggestions how to get this video into Premiere?
    Thanks in advance!
    Sem Offat replied 11 years, 9 months ago 2 Members · 4 Replies
  • Shane Ross
    December 16, 2014 at 5:46 pm
    That camera doesn’t shoot ProRes, it shoots AVCHD. So how did they convert the footage to ProRes?
    Shane
    Little Frog Post
  • Sem Offat
    December 17, 2014 at 5:11 pm
    It’s quite possible it’s a different camera. I can’t read the guy’s writing. It could be AF150.
  • Shane Ross
    December 17, 2014 at 11:59 pm
    Still Panasonic…still an AF camera. That line only does what they call “AVCCAM,” which is their flavor of AVCHD. They also have P2 cameras that shoot MXF…DVCPRO HD MXF and AVCIntra MXF. No camera they make shoots MOV.
    Still…how was this footage converted to a MOV file?
    Shane
    Little Frog Post
  • Sem Offat
    December 22, 2014 at 12:32 am
    When I look at the files on the drive, they are .MOV.
    When I look at the properties when the clip is in Premiere (audio only of course) it reads:
    Video data block #1:
    Frame Size = 1920 x 1080
    Compressor = Apple ProRes 422
    Quality = Normal (3.00)
    Just noticed something even more bizarre. Footage shot on ANOTHER day, many months prior, comes into Premiere totally fine. It reads:
    Frame Size = 960 x 720
    Compressor = DVCPRO HD 720p60
    Now I’m guessing these were shot on two different cameras? So confusing…
