Activity Forums VEGAS Pro .mov / h.264 file info in Vegas 8
  • .mov / h.264 file info in Vegas 8
    Posted by Jeff Beddow on March 30, 2010 at 2:00 pm
    I spent a lot of time in V8 last year but have been away for a while. When I opened a .mov from my Nikon s8000 recently, there was no audio track imported or visible. I have 2 questions:
    How do you use Vegas to read the source file properties?
    Do you need to pre-convert this file for Vegas to see the audio? And if so, is there good freeware for this? (Ok 3 questions)
    Thanks for any help.
    Jeff Beddow replied 16 years, 5 months ago 3 Members · 3 Replies
  • John Rofrano
    March 31, 2010 at 1:40 pm
    You can’t but there is a great free utility called GSpot that can. It will not only tell you what codec you need but it will also tell you if it’s installed on your PC.
    Yes, quite often you need to convert files from whatever format a particular camera shoots into a format that is easier to edit. Some free utilities to do this are AviDemux, MPEG Slipstream, and Super(c).
    It is important to point out that Vegas expects to see certain audio codecs with certain video codecs so while these programs will allow you to mux any type of video and audio together, it may not be a combination that Vegas can support. I would stick with PCM audio which is almost always supported and is also the highest quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Hallgeir Gjesdal
    March 31, 2010 at 8:28 pm
    The easy solution is to simply rename the file-extension to mp4 and try loading it onto your timeline..
    The proper way of doin this is to use bundled software that came along with your camera, and covert to a useful format..
  • Jeff Beddow
    April 1, 2010 at 9:05 pm
    This is very helpful…but I found that iMovieHD 6, which was tucked away in my old Mac laptop, reads and edits the files just fine, although there is a long load time while it converts the file to something it can manipulate more easily.
    I used the Nikon Transfer utility to bring the file out of my s8000 into my Wintel machine, and have the most recent quicktime installed. But Vegas 8 doesn’t seem to recognize this without some kind of conversion.
