Activity Forums Adobe Premiere Pro Mov file wont import into Premiere 5.5
  • Mov file wont import into Premiere 5.5
    Posted by Jamie Burkhardt on August 18, 2014 at 10:13 pm
    Hello everyone,
    I’ve recently tried importing a .mov file into premiere 5.5 and I get the error message: “the codec is missing or unavailable”. The file will only play in VLC, it will not play on any other media player. Not even Quicktime after an update. I’ve never had this issue before and I’m dumbfounded. I even tried uploading the file to YouTube just for kicks and YouTube was unable to process the file. The file is from a Sony handycam HD. Are there any codec solutions out there or converters that will tolerate this file? Any solutions/suggestions are appreciated.
    Jamie
    Jamie Burkhardt replied 12 years, 1 month ago 3 Members · 3 Replies
  • Kevin Monahan
    August 18, 2014 at 10:39 pm
    Hey Jamie,
    Sounds like you need to reactivate your royalty based codecs. Choose Help > Deactivate, restart Premiere Pro. then choose Help > Activate. That should help you.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Jeff Pulera
    August 19, 2014 at 4:22 pm
    Hi Jamie,
    What can be helpful in Premiere is to use this method of importing –
    1) Copy ALL media from camera card to hard drive, all folders intact.
    2) In Premiere, use Media Browser for the actual import
    Jeff Pulera
    Safe Harbor Computers
  • Jamie Burkhardt
    August 19, 2014 at 4:38 pm
    Thanks everyone for your help. I was able to obtain the raw MTS files for import. This edit job is for a client and he had sent me these wacky mov files that wouldn’t import. Obtaining the MTS files was much easier.
    Thanks for your help!
    Jamie
