Activity Forums VEGAS Pro .Mov file not synced: Vegas reads audio & video as different lengths in same file (?)
  • .Mov file not synced: Vegas reads audio & video as different lengths in same file (?)
    Posted by Hannah Jacobs on October 26, 2012 at 4:42 pm
    Yikes. I was sent a .mov recording from a GoToMeeting presentation (the .mov is when it’s recorded on a Mac, it’s the only version I have)
    The video/audio plays fine in Quicktime player and VLC, but when adding the .mov to Vegas Pro (both v.11 and v.12), the audio track can be seen to be physically shorter in the track than the video, and they’re not synced up.
    General
    Type: QuickTime
    Size: 160.56 MB (164,414,797 bytes)
    Streams
    Audio: 01:57:57.248, 16,000 Hz, 32 Bit (IEEE Float), Mono, AAC
    Video: 01:58:38.400, 30.000 fps, 1152x720x24, H.264
    Yep… Vegas reads the audio as being shorter than the video even though they’re actually the same length!
    I ungrouped the video/audio tracks and changed playback of video to 1.06 and doing that makes it *close* to syncing, but not perfect.
    UPDATE: The same issue exists when loading the .mov into Camtasia 8 and ImTOO Video Converter, so it’s not a Vegas glitch, but that makes it even more of a problem.
    Has anyone ever had this issue? Ugh, any suggestions would be greatly GREATLY appreciated, thanks!
    Hannah Jacobs replied 13 years, 10 months ago 1 Member · 1 Reply
  • Hannah Jacobs
    October 26, 2012 at 7:08 pm
    Well that was 4.5 hours of my life I’ll never get back. After many attempted failed workarounds, after ungrouping the video & audio tracks, I set the video playback rate to 1.005 which synced up the tracks enough that it’s workable (since it’s just a powerpoint video, not a talk head).
    I’ve grouped the two tracks back together, and as long as the sync doesn’t get thrown off when I started editing out parts, it’ll work.
