Activity › Forums › AJA Video Systems › .mov different on PC than Mac?! AJA 525 codec to blame?
  • .mov different on PC than Mac?! AJA 525 codec to blame?
    Posted by Ajpme on November 19, 2005 at 1:26 am
    I captured footage from Beta SP using the “AJA 525 29.97 DV” settings. I then exported this to a quicktime and transferred to a PC. The file looks great in Quicktime on the Mac, but when played back on Quicktime 7 on the PC there is extra noise created by compression artifacts. I thought maybe it was a codec issue, so I installed the AJA codec for PC program. That didn’t help either so I reexported via Quicktime conversion to the “DV NTSC 48k” codec. Again it looked great on the Mac and extra compressed on the PC. Anyone know why???
    Fred Connors jr. replied 20 years, 10 months ago 4 Members · 3 Replies
  • Steve Covello
    November 19, 2005 at 1:49 am
    If you don’t really need to export, don’t. Just take the original QT media on your media drive and use that. If you need to assemble or edit your captured media first before exporting, use the export dialog and choose Quicktime Movie, NOT Quicktime Conversion. By choosing Quicktime in export, you will be exporting in the native compression rate of your project as a clone. If you still get artifacts from this, then I dunno…
    steve covello
    double wide post
  • Gary Adcock
    November 19, 2005 at 12:22 pm
    [AJPME] “That didn’t help either so I reexported via Quicktime conversion to the “DV NTSC 48k” codec. Again it looked great on the Mac and extra compressed on the PC. Anyone know why”
    I agree with Steve, if you are using AJA’s windows codec, it should be able to see the QT file correctly.
    But to answer your question, you could be seeing a reversed field issue, but most likely the difference between how the 2 operating systems screen “rendering intent” is different. The Gamma of your Mac display is 1.8 and your PC diplays gamma is normally 2.2
    The 2 images should look the same on a NTSC / PAL Television however
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL USA
  • Fred Connors jr.
    November 20, 2005 at 6:04 pm
    Check the quality setting of the playback on the PC. I believe it is under movie properties. Make sure high quality is checked.
    The file should look the same on both the mac and pc, except for monitors setting of course.
    And the AJA codec is meaningless if you have converted the file to DVNTSC codec.
    Fred
