Activity Forums Adobe Premiere Pro .MOV clips are now playing as white noise in the sequences. Premiere Pro CS5
  • .MOV clips are now playing as white noise in the sequences. Premiere Pro CS5
    Posted by Steve Mac kenzie on May 6, 2012 at 6:57 pm
    Some .Mov clips I was previously working on are all playing as white noise. Quicktime updated to 7.71 from 7.68. IS this a known issue? Should I do a system restore to take it back to the other version or are there other possibilities.
    Clips are Injested SD 10 bit uncompressed….
    System specs below.
    Chipset: Intel x58-GigabitLAN-(6) SATA 3.0Gbps-(2) SATA 6.0Gbps-1394a-(12) USB
    2.0-(2) USB 3.0-(1) eSATA
    Included
    CPU: Intel Core i7-960 Quad Core Processor 3.20 GHz 4.8 QPI
    System RAM: 12GB (6x 2GB DDR3-1333)
    System Drive: 160GB Solid State Drive (SSD) +250MBps Read/+70MBps Write
    Spare Drive: 1.5TB SATA 3Gb/s NCQ 32MB Cache 7200RPM
    Display Adapter: NVIDIA Quadro FX1700 512MB DVI/DVI PCI-e
    Primary Optical Drive: LG Blu-ray/DVD/CD Recorder w/Cyberlink
    Internal Video Raid: 2x 1.5TB SATA 3Gb/s NCQ 32MB Cache 7200RPM 3TB RAID-0
    Thank you for your help!
    Steve Mac kenzie replied 14 years, 4 months ago 1 Member · 1 Reply
  • Steve Mac kenzie
    May 6, 2012 at 8:53 pm
    How do I adjust this? Fresh clips playing fine before are cranked now in new sequences. I cleared all of the peak Audio files and the rendered things. I also did away with the new Quicktime update.
    Thanks again…
