Mount Library on Maxx Digital SAN
So, I have project files (libraries) on our SAN and I’m using FCPX 10.1.2 for an occasional project. (mostly using Premier)
I had to have Bob Zelin setup the ability to mount the SAN through NFS and I’ve been able to open project files and it works OK. It’s great if you just stay inside FCPX, but if you need to navigate the san folder structure or do any file manipulation, it’s a bit messy.
Well, I had my san mounted traditionally (AFP) and then opened FCPX and it opened a project file from the SAN. This normally doesn’t happen, it usually just ignores projects I had opened like the volume is unmounted. I revealed some files in finder and everything seemed to be working fine.
I closed the library and tried to reopen and got the message about the volume type not being supported.
Is there a way to trick the software? Any chance this gets resolved anytime soon? I’d love to implement FCPX into our workflow…it’s a superior piece of software for the corporate projects we do in many ways.
