Activity Forums Apple Motion Motion2 Crashes After Installing Tiger
  • Motion2 Crashes After Installing Tiger
    Posted by Humbertogranados on July 27, 2005 at 5:27 pm
    MOTION 2 WILL NOT TURN ON
    Sat july23 2005 I purchased and installed Final Cut Studio following the install manual. All programs (final Cuts, live type, soundtrack pro, and Motion 2) worked properly on the panther operating system.
    Later that day- I noticed that the Blackmagic Codec
    Humbertogranados replied 21 years, 2 months ago 2 Members · 2 Replies
  • Scot Walker
    July 27, 2005 at 7:24 pm
    I had a similar problem where Motion 2 would not launch, and I tried everything.
    I ended up installing Tiger on another drive, a clean install. You have something loading when you boot Tiger that causes problems with Motion 2. The only way to get rid of it is to do a clean install, not an upgrade install. Wipe everything and install Tiger then install Motion 2, then launch Motion 2 and it should work.
    OS X really does need a System Restore feature like Windows. Initially, OS X applications were suppose to be completely self-contained and not rely on anything outside of the bundle. That’s just not the case anymore.
  • Humbertogranados
    July 27, 2005 at 7:42 pm
    If that’s your only solution, I think you maybe right. I’ve
    tried everything accept Un-installing re-installing Quicktime as someone esle
    suggested.
    We’ll see if this works.
    thanks
