Activity › Forums › RE:Vision Effects › Motion Vectors out of Maya and vray
  • Motion Vectors out of Maya and vray
    Posted by Byron Nash on September 10, 2011 at 12:49 am
    Can you use the Velocity pass from a Maya vray render with RSMB? We used the 2d Motion Vector pass in mental ray on a previous project but will be rendering in vray on this job. The velocity pass looks different than the Motion Vector Pass.
    Byron Nash
    3D Artist
    http://www.editatjoes.com
    Pierre Jasmin replied 15 years ago 2 Members · 1 Reply
  • Pierre Jasmin
    September 10, 2011 at 2:27 am
    Yes it looks different — and you are not alone with that problem
    I wrote to them again today, if you have some “5 frames” sequence (rgba and velocity pass) bring it on (use the contact form https://revisionfx.com/support/contact/ to get an ftp download area if needed – and then tell us where it is).
    All I know is it is not scaled so there is negative motion in the image so it will work only in 32b but there seems to be a larger problem from my earlier tests.
    What is good to trouble shoot is 1 frames static – no motion, and then a simple object like a cube like moving 20 pixels in X per frame and 10 in y per frame or something like that.
    Pierre
    RE:Vision Effects
