Activity › Forums › Apple Motion › Motion Updae
Motion Updae
Posted by James Thomas on March 3, 2015 at 2:48 pmI just updated my iMac to yosimite not knowing my motion 4.0.3 wouldn’t work. Is there an upgrade, or do I have to purchase 5?
Robin S. kurz replied 10 years ago 5 Members · 9 Replies -
Tim Jones
March 3, 2015 at 4:40 pmIt’ll be $49 well spent, but you will need to upgrade.
Tim
Tim Jones
CTO – TOLIS Group, Inc.
https://www.tolisgroup.com
BRU … because it’s the RESTORE that matters! -
Robin S. kurz
March 4, 2015 at 9:22 amIt’d be entirely new to me that Motion 4 DIDN’T run under Yosemite, nor do I see any reason why it shouldn’t. And yes, 4.0.3 is the most recent version of 4.
Keeping v4 would also only make any sense if you’re (actually) still running FCP 7. Which would of course be shooting yourself in the foot on a Yosemite compatible machine. 😉
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
James Thomas
March 10, 2015 at 4:33 pmWhen I try to open motion it says
“You can’t use this version of the application “Motion” with this version of OS X”
“You have “motion” 4.0.3. -
Robin S. kurz
March 10, 2015 at 4:37 pmWell, all I know is, that I have both running just fine. You may want to consider a re-install… or just plain get v5 and what else goes with it.
– RK
Steve Cohen
August 26, 2016 at 12:43 amI had Motion and all the FCP 3 applications working fine under Yosemite.
I just upgraded to El Capitan because my Office 365 suite would not work under Yosemite and discovered that QMaster and Motion will not work.
QMaster I don’t care about, but Motion could be a problem.
Maybe I’ll instal a Virtual Machine version of Yosemite and Motion 4.0.3 if I really need it.Steve Cohen
Robin S. kurz
August 26, 2016 at 12:14 pm[Steve Cohen] “Motion will not work.”
That may be in your particular case, but that doesn’t change the fact that it does work. Be it Yosemite, El Capitan or even under macOS Sierra as I now know. So it’s clearly not an issue on Motion’s side.
– RK
Steven Cohen
August 26, 2016 at 5:27 pmI’m just posting my experience.
It has worked for me so it may work for others as well.
Up until El Capitan it worked fine.Steve.
Tim Jones
August 26, 2016 at 6:12 pmRobin – have you disabled SIP / rootless on your El Capitan system? I just updated a 10.9.5 test system that has FCPS 2/Motion and none of the apps work due to the secure system folders.
I can see how this would work if you have disabled SIP / rootless mode on your 10.11 system, but all of the tools in FCPS are reporting errors after I upgraded that system with SIP enabled.
Tim
Tim Jones
Robin S. kurz
August 27, 2016 at 8:54 amMea Culpa. I just realized that I DON’T have Motion 4 installed on the machine in question after all. Oops. 😛 I just saw my “Final Cut Studio” folder in the applications and assumed Motion was still in there also. And since I recently booted up FCP 7 to check something, I assumed all was good.
I could reinstall it, but… I just don’t care. 😀 I haven’t used any FCS3 apps (other than for maybe double-checking on some old command or interface element etc.) in over four years and wouldn’t even know why I would want to. Complete waste of time and resources imho. Clunky and inefficient. They’ve all been dead for over five years for a reason.
Get Motion 5 for a measly 49 bucks… “problem” solved.
– RK
