Activity Forums Adobe After Effects Motion Tracking – Weird Text Twist Problem
  • Motion Tracking – Weird Text Twist Problem
    Posted by Chase Wichert on January 7, 2012 at 5:34 am
    Okay so I have an animation I created in 3DS Max, and as an after thought I decided I want text that appears stationary in the video. So I tried motion tracking, however when I assign my text to the null object as the video plays the text twists or rotates slightly independed of the null object. I have it set as a 3d layer so I can rotate it and get it looking correct, it is 2d text that was created by right clicking and selecting new-> is after effects cs5. Also my settings for the tracker are:
    Transform
    Position
    Rotation
    (and I have tried Scale)
    I have also tried the combinations of all of the position rotation and scales. Any know what is going on?
    Thanks in Advance!
    Erik Waluska replied 14 years, 8 months ago 2 Members · 4 Replies
  • Erik Waluska
    January 7, 2012 at 7:49 pm
    Why not just render out the text in 3DS Max using the same scene you created the video with? That way the camera move and lighting would match perfectly. Just render the text by itself and composite it in AE if you don’t want to render the whole thing again in 3DS. Should render pretty quickly if you optimize the scene and just use basic lighting and materials for the text.
  • Erik Waluska
    January 7, 2012 at 8:04 pm
    You can also export the camera data from 3DS max to AE.
    https://www.videocopilot.net/blog/2008/02/import-3d-camera-into-after-effects/
  • Chase Wichert
    January 7, 2012 at 10:18 pm
    Hey, thanks! I thought about doing that and I still might, however I am into learning new things so I wanted to figure out why it wasn’t working, and I found out that Mocha tracks it much better, because there is a large zoom and rotation that happens. Thanks again for the advice!
  • Erik Waluska
    January 8, 2012 at 12:14 am
    You bet. Very true, Mocha can do a nice job matching perspective changes and can do it pretty quickly once you get the hang of it.
