Motion Tracking w/ Shape Layer: How Do I Position The Shape After Tracking?
Hi Everybody 🙂
Pulling my hair out here as surely there is a darn simple explanation (and you’ll probably slap your forehead at the stupidity of my problem) but…just haven’t been able to figure this out as all of the tutorials I have watched fail to fill me into my particular issue. I’m working with AE CS6 and essentially I have a fairly large section of video (about 40% of the frame) that I’d like to have blacked out with a square via the shape layer. In order to ensure that the shape seamlessly blacks out the area I need, I have applied a motion track and have targeted the shape layer as the shot is a little shakey at times. All is well, tracking is great. However, the square on the shape layer is not where I need it to be and naturally if I reposition it after the fact, the tracking points are rendered useless. How the heck do I position the square on my shape layer in the exact spot I need it to stay at AND then have the tracker use that position as the place it needs to stay? Thanks much 🙂
