Activity Forums Adobe After Effects Motion Tracking Troubles
  • Motion Tracking Troubles
    Posted by Iggy350 on August 21, 2007 at 4:02 pm
    Help Meeee!!
    I’m losing my mind here.
    I want to track something that starts offscreen and comes onscreen.
    I start at the last frame of the scene and track backwards,..but when it gets to the edge it doesn’t go offscreen.
    Someone told me i had to precomp and increase the size.
    So I did that, went back and tried ago
    It STILL stops at the edge.
    I’ve tried every combination of Extrapolate at 70%,80% & 90%
    I’ve tried it with Subpixel positioning on and off
    I’ve tried it with Adapt feature on every frame on and off.
    I also tried tracking RGB AND Luminance.
    Its really starting to wind me up now, I know it should be simple to sort,..so why can’t I?? 🙁
    IGGY35
    http://www.youtube.com/iggy35
    Jimmy Brunger replied 19 years ago 4 Members · 3 Replies
  • Mike Procunier
    August 21, 2007 at 5:00 pm
    AE tracks pixels, so when they go off screen the tracker gets lost. You have to manually move the track points off screen. It ends up being a lot of trial & error. Check out Aharon Rabinowitz’s new tutorial on tracking with Mocha & be amazed.
  • Peter O’connell
    August 21, 2007 at 5:34 pm
    You can just move the little plus sign at the middle of the tracker by hand. This is the attach point that all calculations are based on.
    Pete O’Connell
    http://www.barxseven.com
  • Jimmy Brunger
    August 22, 2007 at 7:34 am
    Everyone should have bought Mocha when it was
