Activity Forums Adobe After Effects Motion Tracking Q
  • Motion Tracking Q
    Posted by Kayla Emter on October 2, 2008 at 2:19 am
    Is there a way to use motion tracker’s scale function to track a shot that’s dollying back from a stationary subject an in effect cancel out the dolly move to make a static shot and not get the Vertigo effect? I’m guessing not but figured I’d put it out there.
    David Bogie replied 17 years, 11 months ago 3 Members · 2 Replies
  • Alex Dinnin
    October 2, 2008 at 11:41 am
    The only way to do would be to affect the scale of your image.. as I undersand you correctly you want to track a camera pull back.
    so you could use an expression on the scale of the image but it would obviously pixelate !!
    apply the tracking scale data to a null..
    then on your image use a lin expression to re size it.
    hope this answers your question
    Alex
  • David Bogie
    October 2, 2008 at 4:00 pm
    The “Vertigo” effect you refer to was invented long before Hitchcock’s photographers used it. the idea is a matched zoom and dolly to maintain a relative image size, usualy the foreground subject, while the background image changes magnification. You can do this in AE using simple scaling or a very nice 3D move if the foreground and background are on separate layers.
    Not sure why you’d need to that using Motion Tracking, though.
    You may want to reverse-stabilize the shot so the background looks like it was shot at the same time.
    bogiesan
