Activity Forums Adobe After Effects Motion Tracking concept not grasped
  • Motion Tracking concept not grasped
    Posted by Tim Vanbrackle on November 6, 2011 at 6:05 am
    I am perplexed and need help. I am trying to stabilize some tracked footage:
    https://www.youtube.com/watch?v=tsyAZeVKvY0
    I am using the motion tracker in after effects in cs5. I set up a green screen (ps. I know it’s a bad key, and thats not the background i am going to use, right now just want the footage smoothed out for a tracking shot to put in a background later)
    I used a glide. I wanted the motion tracker to stabilize the x axis, but I still get the “floating bar look”. (plus it slides off the side of the screen.) am i totally using the wrong tool for this? Any help would be greatly appreciated thanks.
    Roland R. kahlenberg replied 14 years, 10 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    November 6, 2011 at 10:21 am
    Posting the original chroma footage will help (without any post on it).
    Since the perspective changes in your shot, I would choose a 3d tracker like Camera Tracker from the Foundry. This will give you a camera in AE that matches the real camera. That will enable you to composite a background that will match not only the move but the perspective change as well. Then you can deal with stabilizing the move on the Y axis (not the x axis- that’s why the image moves to the side).
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Roland R. kahlenberg
    November 6, 2011 at 2:48 pm
    WoW! Lots of issues here with your production techniques.
    Not only are your markers colored wrongly but they compound your issues by having been erroneously placed such that they cut into your foreground characters.
    As for your post correction on stabilizing, take a look here – https://library.creativecow.net/articles/swanson_grant/Final2_mixdown2.php
    Do take note that you will have to rotoscope out the markers, which isn’t covered out in the linked tutorial. The rotoscope requirement isn’t too difficult if you cut some slack on the edges of the hair but it’s still a lot of unnecessary work!
    Now, back to your main issues, which involve production techniques and values. Do set aside a budget for an, on-set VizFX Supervisor the next time you venture out on a VizFX job. This shoot was done without an idea of how to piece things together in post and that’s a disaster already in the happening. ‘Fix it in post’ is bad enough a thought, even when a solution to how to fix it in post is known.
    The COW’s job forum and your own contacts will allow you to link up with folks that will not only do the job but allow you to assimilate some useful knowledge/tips while on the job.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
