Activity › Forums › Adobe After Effects › Motion Tracking
Motion Tracking
Posted by Cutter Johnston on December 7, 2006 at 2:12 pmI am shooting a clip and swapping out the existing billboards with other clips. Would motion tracking work to “attach” the clips or would keyframing be the way to go?
Cutter Johnston replied 19 years, 9 months ago 3 Members · 6 Replies -
Cutter Johnston
December 7, 2006 at 2:39 pmPete’s rotoscoping tutorial is the way to go! Thanks Pete!
Tony Kloiber
December 7, 2006 at 5:44 pmTracking is an automated way of adding keyframes. You’ll fine that you probably will do a bit of both. Do a 4 point (Perspective or parallel corner pin) track. I would make a soild the size of the object you want to add and appy the tracking data to that and then parent your real object to the soild I think! There is the choice in the ‘edit target menu’ of ‘apply to effect point’ but it was greyed out. Not sure what I had setup wrong there. I have not done a 4 point track since the new (7) version of AE.
BTW I just did the Shake Tutorial on this subject and Shakes tracking setup was great.
TonyTony
Mike Clasby
December 7, 2006 at 6:14 pmI thought that tut was great too, but if you’re changing perspective you might want to look at these:
Keep motion in perspective
https://studio.adobe.com/us/tips/tip.jsp?p=1&id=100241&xml=aft65cornerpin
Using the new Motion Tracker
https://studio.adobe.com/us/tips/tip.jsp?p=1&id=487&xml=aft6ttmotiontracker
And this if part of your track leaves the screen:
Tracking obscured objects in video
https://studio.adobe.com/us/tips/tip.jsp?p=1&id=399&xml=aft6tracking
And 5 min into Aharon’s tut is how to manually fix a cranky track
https://forums.creativecow.net/articles/rabinowitz_aharon/cartoon_look/CC_LiveTrace_Pt_3CD.mov
Tony Kloiber
December 7, 2006 at 8:11 pmYikes! Mike can you say cranky track in this forum 😉
TonyTony
Cutter Johnston
December 8, 2006 at 4:55 pmThanks for all the feedback! Now to work. I want this animation presented by January 14th.
