Activity Forums VEGAS Pro Motion Tracking 4 video clips on a track in SVP 11 using Match Move/Corner Pinning?
  • Motion Tracking 4 video clips on a track in SVP 11 using Match Move/Corner Pinning?
    Posted by Ansh Gujral on September 3, 2016 at 3:21 pm
    I am trying to motion track 4 video clips on a single track.
    https://youtu.be/I_AskX5WsM8
    Now as you see in this embedded video there are four images in the track, What I would like to do is to map video clips to each of these images so that when the camera moves the video clips move according to their mapped region.
    From what I read here I should be using Corner Pinning or Match Move with ‘Nested Project’ in SVP and though I do get the concept I’m unable to comprehend it as a whole. So if someone could help me with step by step instructions that would be great.
    László Kovács replied 9 years, 11 months ago 3 Members · 4 Replies
  • John Rofrano
    September 4, 2016 at 4:17 am
    [Ansh Gujral] “From what I read here I should be using Corner Pinning or Match Move with ‘Nested Project’ in SVP and though I do get the concept I’m unable to comprehend it as a whole. So if someone could help me with step by step instructions that would be great.”
    You will want to do this 4 times on 4 tracks. Once for each video you need to track. If you are referring to BCC Match Move there is an option to render only the move without the background. That is what you want to do for three of them. Then just place those nested projects on a track above the 4th one and all of them should appear to track together
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Ansh Gujral
    September 13, 2016 at 10:10 am
    Thank You for your prompt reply Mr.John. So what I get from your explanation is I should be working on 3 different nested projects with each nested project having the Foreground video I would like to map onto the the Background video so that it moves with it’s mapped regions. And these 3 nested Projects should be rendered without the background video.
    Another problem I’m facing is even in nested projects I can use match move only from the beginning of the clip but I would like to match move somewhere in the middle of the clip.
    Just to be clear again I am posting another video.
    So I would like to map video clips to each of these images (overlaying the images with the video clips) so that when the camera moves the video clips move according to their mapped region.
    -Ansh
  • John Rofrano
    September 13, 2016 at 11:26 pm
    [Ansh Gujral] “Another problem I’m facing is even in nested projects I can use match move only from the beginning of the clip but I would like to match move somewhere in the middle of the clip.”
    Sorry it doesn’t work that way. You can only use Match Move at the beginning of a clip. You need to make any clip that needs Match Move a nested project. Then put the nested project anywhere you want on your master timeline.
    ~jr
  • László Kovács
    September 14, 2016 at 7:29 am
    I just took a closer look of your problem now.
    If the background is a screenshot that you are making to move, there may be on other approach.
    Is it a screenshot you made, and move with pan/crop or track motion?
    Best regards
    László Kovács
