Activity Forums Adobe After Effects Motion tracker – target layer won’t lineup
  • Motion tracker – target layer won’t lineup
    Posted by Scott Thomas on August 27, 2009 at 11:42 am
    I am hoping there is a simple solution to this.
    I have tracked 2 points on a TV screen that was filmed hand-held. the Tracker was set to Track motion. The resulting tracks are good and accurate.
    When I apply the tracks to the layer I want to matte in, the target layer always rotates, rescales and repositions. If I select all the keyframes and nudge the rotation, scale and position parameters I can get the target layer back in alignment.
    But this is a pain, so I need to know why the slide is repositioned in the first place. Is there something I can do in the positioning of the slide before applying the motion track to this layer.
    Any advice or directions to advice is appreciated.
    Scott Thomas replied 17 years ago 2 Members · 2 Replies
  • Todd Kopriva
    August 27, 2009 at 5:41 pm
    Did you just choose Position when you told After Effects what kinds of keyframes to generate during tracking? See “Track or stabilize motion”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Scott Thomas
    August 27, 2009 at 6:34 pm
    Hi Todd. I have chosen either Position+Rotation or Position+Rotation+Scale.
