Motion Track Question – How to not track on some frames and continue tracking on others?
I’d like to use perspective corner pin motion track on a screen to add something else over it. But I know that at some point there will be an object passing over the screen. This object will obviously mess with the tracking if I don’t mask it but the thing is I don’t want to mask it because the tracked image doesn’t move at that point at all. So is there a function I can use to not continue trying to find a source to track but instead track the same point it was a frame earlier and after that I can resume normal tracking after the object has passed?
In summary; how to keep tracking points still on a certain time I want and resume later?
I’m very new and weak on the terminology, apologies if I’m not being clear enough.
Regards
