Activity › Forums › Adobe After Effects › Motion Track a Moving Puppet
Posted by Seb Mackintosh on December 8, 2009 at 11:21 amHi,
I’ve got four different puppets in a composition. I’ve animated the first one (a person). He’s pushing a cart and I want to sync the cart movements to his waist.
I think motion tracking only works with rendered video, not other effects/stills. Can anyone suggest how to do this?
Regs
Chris Wright replied 16 years, 9 months ago 3 Members · 6 Replies -
Bartek Skorupa
December 8, 2009 at 12:22 pmLet’s say your layer with puppet tool is called “Layer1”
Let’s say that the absolute position of the other layer should be the same as the Puppet Pin 1 absolute position.Place the following expression to the position of this other layer:
L=thisComp.layer(“Layer1”);
pin1=L.effect(“Puppet”).arap.mesh(“Mesh 1”).deform(“Puppet Pin 1”).position;
L.toComp(pin1)voila
Bartek Skorupa
Warszawa, Poland -
Seb Mackintosh
December 8, 2009 at 12:41 pmThat’s great…
Do I need to change this for relative position?
Are there any good resources for me to read about expressions – and would using a pickwhip do anything like this?
Tks!
Bartek Skorupa
December 8, 2009 at 1:12 pmIn fact I did’t write much.
I did as follows:
1. Alt-click the position.
2. write down:
L=
3. pick whip to the “Layer1” name.
4. write down:
5. hit enter (return)
6. write down:
pin1=
7. pick whip to the position of the pin
8. write down:
9 hit enter
10. write down:
L.toComp(pin1)I had no idea about what “blableeblablee” stuff will be written. I only new the principles of “toComp” thing.
Bartek Skorupa
Warszawa, Poland -
Seb Mackintosh
December 8, 2009 at 1:23 pmWorking a treat. I’ve also tried just adding the difference in the X dimension at start point to .position and that works.
Now I see I’ve created a problem. My pusher man stretches back before then moving forward and the wheel is tied to him so also flies backwards. Not a good look!
I can’t find any material on how to only introduce the linked expression after a point in time (or a keyframe)…I’m guessing unless there’s a keyframe option, it’s an if clause of some kind…aaarrgghh…the things you do to learn this stuff!
Tks!!!
Chris Wright
December 9, 2009 at 6:54 amto parent a layer object to a pin
and if the cart is a normal layer…L = thisComp.layer(“face”);
L.toWorld(L.effect(“Puppet”).arap.mesh(“Mesh 1”).deform(“Puppet Pin 1”).position)
and to parent a pin to a Null…
https://forums.creativecow.net/readpost/2/969088https://technicolorsoftware.hostzi.com/
Chris Wright
December 9, 2009 at 6:03 pmand btw, if you precompose your pins, the newcomp can be fully motion tracked and then parented in any way you want.
