Activity › Forums › Apple Final Cut Pro Legacy › motion to fcp
motion to fcp
Posted by Jack Fox on December 20, 2008 at 5:42 pmI have a 15 second scrolling text that I created in Motion. No matter how I export to movie or import using fcp, the quality is not good. (It is 23.98 frames per second.) It looks great in Quicktime Player, but when I import the .mov file into a 23.98 sequence in fcp it looks terrible.
jmf
Jack Fox replied 17 years, 9 months ago 4 Members · 7 Replies -
Jerry Hofmann
December 20, 2008 at 6:52 pmHow are you monitoring the quality of the picture? If on your computer’s display, that very well could be the problem… what format are you exporting? What were the project settings in Motion?
Post what format you’re working with in FCP as well. You need to match the project settings in Motion to the sequence settings in FCP.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Tom Wolsky
December 20, 2008 at 8:51 pmThe frame rates are different to start with. The Motion project is 29.97.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Arnie Schlissel
December 20, 2008 at 8:56 pmYou have a number of issues here, Jack.
First, you’re working at 2 different frame rates. Your Motion project is 29.97, but your FCP timeline is 23.98. They should both be the same.
Second, you’re compressing everything to DV in your timeline. It’s very difficult to keep good quality with graphics in DV.
Finally, you don’t say how you’re monitoring. You should be looking at a video monitor, not your computer monitor. Your FCP manual has a series of diagrams that will tell you how to hook up a video monitor using different types of equipment.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Jack Fox
December 20, 2008 at 9:22 pmThank You. I will make the changes you raised, and report back. My monitor is a JVC TM-H1150C.
jmf
Jack Fox
December 21, 2008 at 3:55 amOkay, I did make the changes but I think it was the frame size that made the real difference. The Motion setting was 720×486 and the FCP size was 720×480.
jmf
