Activity Forums Apple Motion Motion Titles Look Bad
  • Motion Titles Look Bad
    Posted by Andrew Holt on May 16, 2008 at 4:14 pm
    Hope someone can help!
    Iam curently using final Cut Pro HD and Iam working with a DVCPRO50 – PAL Sequence, I export it as a Quicktime Movie or Send it from the Timeline to Motion, I make my titles up, some just fadeing up and some moving across the screen. I then Export from Motion as a Quiktime Movie DVCPRO50 – PAL. Then I import into Final Cut, and the Titles dont look Sharp and a bit shakey! And when I export to DVD they still look as bad. I have viewed the Output on Plasmas,LCD etc I just Cant seem to get clean titles. I made up a title in Adobe Photoshop using a Resolution of about 300 just as a test and that looks really sharp in Final Cut and on the Output. What am I doing wrong?
    Andrey Chernyshev replied 18 years, 4 months ago 3 Members · 3 Replies
  • Noah Kadner
    May 16, 2008 at 11:01 pm
    Try exporting as uncompressed out of Motion, then import into FCP.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
    https://www.callboxlive.com
  • Andrew Holt
    May 19, 2008 at 1:30 pm
    Thanks for the suggestion. I gave it a try but sadly its not helped.
  • Andrey Chernyshev
    May 26, 2008 at 11:21 am
    Andrew, I’m not an expert in Motion yet, but I’ve seen somewhere a suggestion to output your titles from Motion as a self–contained QuickTime movie and then import that movie in FCP. You might want to give it a try.
    Andrey Tchernyshev
