Activity › Forums › Apple Motion › Motion templates imported to Final Cut play back white
  • Motion templates imported to Final Cut play back white
    Posted by Michael Lynch on October 1, 2007 at 9:47 pm
    This is the first time I’ve tried to use Motion templates directly in FCP via Sequence > Add Master Template. The template is added and the controls appear in the controls panel, but the viewer only shows white. Drag to timeline and canvas shows only white. Trashing prefs made no difference.
    Anyone else run into this? I’m on FCP 6.0.1 and Motion 3.0.1
    Thanks in advance for any assistance!
    MacPro 3.0GHz 8 Core – 4GB RAM
    FCS2; AE; PS
    Peter Wiggins replied 18 years, 12 months ago 2 Members · 1 Reply
  • Peter Wiggins
    October 2, 2007 at 11:34 am
    Have you made sure you are not looking at the alpha?
    The three little buttons on the top of the canvas window – select the right hand side one then check the dropdown menu. Should be RGB not alpha.
    Peter
