Activity Forums Adobe After Effects Motion Sketch: Change start point?
  • Motion Sketch: Change start point?
    Posted by Rosa Jurjevics on April 11, 2012 at 3:23 pm
    Hello, Cowpokes! (couldn’t resist)
    I’ve got a Motion Sketch question. I’ve created a cursor and, using Motion Sketch, have given it some realistic movement. Problem is, I want it to move AGAIN from the position it’s in now to a different spot, and Motion Sketch seems to only capture from 00:00:00.
    My question: Can I change the start point of the capture? If so, how?
    Also: Can you have two motion-sketched paths per layer?
    Thanks so much.
    Darby Edelen replied 14 years, 5 months ago 2 Members · 1 Reply
  • Darby Edelen
    April 11, 2012 at 4:00 pm
    Motion Sketch will place its keyframes at the beginning of the work area until you let go of the mouse, or the end of the work area is reached.
    With that in mind what you can do is change the start of the work area to the time you’d like the motion sketch keyframes to be created from (the shortcut for setting the work area beginning is “b”).
    Also, Motion Sketch creates keyframes that can be moved on the timeline (or in space) just like any other keyframes, so you can revise your timing later. It’s hard, for example, to get two separate Motion Sketch paths to meet properly without moving one of the groups of generated keyframes.
    Darby Edelen
