Activity Forums Apple Final Cut Pro Legacy motion retime (optical) vs Shakes..
  • motion retime (optical) vs Shakes..
    Posted by Simon Blackledge on July 30, 2007 at 9:19 pm
    .. retime the same clip.. shakes output is way better.. Motion seems to still frame blend as well.. anyone less than impressed?
    are you supposed to turn frame blending off in motion ? set to best?
    appears you need to send to motion at 100%.. or fcp frame blending is also applied..
    very unfriendly comprared to shakes.. set to adaptive+Best.. done render. And the results are better.
    p
    Walter Biscardi replied 19 years ago 3 Members · 6 Replies
  • Jeremy Garchow
    July 30, 2007 at 9:25 pm
    Are you selecting optical flow instead of frame blending?
  • Simon Blackledge
    July 30, 2007 at 9:33 pm
    yup..
    it does the spinny grey disk thing thats supposed to show its working out the optical flow..
    sometimes it look ok, ish,. but its not a great optical flow.. it is distorting stuff so its deffo optical..
    oh.. and then your supposed to render the .motn in fcp.. thats even worse than the preview motion shows..
  • Jeremy Garchow
    July 30, 2007 at 9:46 pm
    Don’t know what to tell ya except to use Shake.
  • Simon Blackledge
    July 30, 2007 at 9:56 pm
    No worries.. thanks for input though.
    Pro app update out btw.
    Roll on furnace for fcp..
  • Jeremy Garchow
    July 30, 2007 at 10:13 pm
    [pennello] “Pro app update out btw.”
    Yeah it’s real vague as to what it does.
  • Walter Biscardi
    July 30, 2007 at 10:29 pm
    [pennello] “.. retime the same clip.. shakes output is way better.. Motion seems to still frame blend as well.. anyone less than impressed?”
    Are you talking about Motion the application or the Motion Tab in FCP? If this is about Motion the application, I would post this in the Apple Motion forum, not here.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
