Activity › Forums › Apple Final Cut Pro Legacy › Motion projects
  • Motion projects
    Posted by Chris Whitmore on May 17, 2010 at 2:13 am
    Hi
    again have a question that is making me go crazy in “motion”. I have found that I can make a title bar and save the project and import that project (clip.motn)into FCP and place it over my video clip. (Fantastic) However, I found the quality is very very poor. A logo on my title bar is extremely poor quality. Almost impossible to read the text in the logo! What I have found is if i render export this clip out of motion and then import it into FCP, the quality is fine but as the above explanation, not so good.
    I like the fact that if i use the .motn versions I can make changes, save it and automatically updates in FCP.
    Is there a quality setting that allows that can improve this? Am I saving it wrong?
    Matt Campbell replied 16 years, 4 months ago 5 Members · 11 Replies
  • 11 Replies
  • Michael Gissing
    May 17, 2010 at 2:33 am
    Does the Motion project settings match the FCP settings?
    What are those settings?
  • Chris Whitmore
    May 17, 2010 at 4:17 am
    FCP is running:720 x 576 CCIR 601/DV PAL (5:4)Anamorphic 16:9 25 fps
    Motion project preset ediotr is running: PAL Broadcast SD 16:9 720 x 576 PAL D1/DV Anamorphic 25 fps.
    Both have upper field selected.
    So would have thought that is a match.
  • Michael Gissing
    May 17, 2010 at 5:06 am
    Yes the settings match and are correct. Is everything rendered in the FCP project?
  • Chris Whitmore
    May 17, 2010 at 5:11 am
    yes and the logo is brought straight into motion and rendered onto vision
  • Michael Gissing
    May 17, 2010 at 5:54 am
    Perhaps a screen shot might help us to work out the issue. Also how are you judging the image?
    If FCP is set to 100% in the canvas it gives a more accurate image. Is the final image for web, DVD or broadcast? If the later, then the quality should be judged on an external monitor via an I/O card (Kona, Decklink, Matrox)
  • Chris Whitmore
    May 17, 2010 at 7:07 am
    the final destination is for corporate video and I use a AJA card to a LCD screen. Like I said the if I export the vision as an independent clip, the quality is very good. The .mont version is the issue.
    In fact since talking about this issue I have been making independent clips to get the job done.
    I have all my settings to the highest quality, even when I output from motion to the LCD television.
  • Stephen Smith
    May 17, 2010 at 2:46 pm
    In FCP, go to Settings, Sequence. Then click on the Render Control tab. Set Quality to best.
    Utah Video Productions
    Check out my Motion Tutorials
  • Chris Whitmore
    May 17, 2010 at 10:48 pm
    thank you thank you thank you
  • Kevin Monahan
    May 17, 2010 at 10:54 pm
  • Stephen Smith
    May 17, 2010 at 10:59 pm
    Happy to help and best of luck.
