Activity › Forums › Apple Final Cut Pro Legacy › Motion project
  • Posted by David Carey on July 25, 2008 at 10:07 pm
    Help
    I am working on a very simple Motion project where I am adding a moving yellow bar with black text on it onto the screen from the right. At first the motion was not clear and fragmented but then I applied a motion blur and it got better. At first the bar appeared to have a small grey outline (when there wasn’t really one on the graphic) but I softened the edges a few pixels and that went away. The motion is better but not absolutely smooth and clear. If you stop on it it still looks blurred and fragmented.
    Any suggestions or help would be great
    David Bogie replied 18 years, 2 months ago 2 Members · 1 Reply
  • David Bogie
    July 28, 2008 at 3:36 pm
    [David Carey] ” I am working on a very simple Motion project where I am adding a moving yellow bar with black text on it “
    There are no simple Motion projects.
    [David Carey] Any suggestions or help would be great
    You have not supplied much information: project format, frame rate, image size, your level of experience, how you are determining these are problems instead of simply improper assessment of unrendered material. These would help.
    bogiesan
