Activity Forums Apple Final Cut Pro Legacy Motion problems/ kernal panics
  • Motion problems/ kernal panics
    Posted by Mark Suszko on May 14, 2012 at 3:51 pm
    Apple Motion 4 is crashing from kernel panics every time I ask it to do anything like save, export, import. Re-loaded the OS. Re-loaded Motion 4 and ran the updates. Still happening. FCP7 and FCS 3 is fine, only Motion is misbehaving. What do? Engineer is ready to try a new hard drive. I’m ready to try a downgrade to Motion 3.
    Jerry Hofmann replied 14 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    May 14, 2012 at 11:26 pm
    Sounds to me like a clean install needs to be done. “Reloading” isn’t clean don’t think if I understand what you did… you need to erase your startup disk to perform a clean install or use a new or empty one.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
