Activity Forums Adobe After Effects Motion Path from a layer parented to a Null?
  • Motion Path from a layer parented to a Null?
    Posted by Scott Bush on August 12, 2015 at 7:01 pm
    Hi all.
    I’m trying to make a “tornado” that forms out of a few “stroke” type lines and some particles as well.
    The best way I know to make a 3D motion path spiral that is fully custom and controllable is to use a light parented to a null, then animate the null object so the light ‘orbits’ around it.
    But I need the motion path that the light follows, and I need to use it on several different layers. When I use a light parented to a null, the null has a motion path but the light doesn’t. How can I ‘extract’ a motion path from the light itself after it is parented?
    (I’m aware of expressions I can use to make spirals but the ‘tornado’ I’m making is stylized and custom, so the ‘perfectness’ of the resulting spiral isn’t what I’m looking for — I need to follow the style frames I was given.)
    I feel like this should be so simple but I’m having a hard time with it. Any help appreciated.
    Kalleheikki Kannisto replied 11 years, 1 month ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    August 13, 2015 at 9:19 am
    I don’t know of a way to create a motion path from that setup, but you can always pick whip and link various things to the position value of the light, if that helps.
