Activity › Forums › Adobe After Effects › Motion path + bending along path?
  • Motion path + bending along path?
    Posted by Ryan Hill on May 8, 2012 at 7:36 pm
    For an example, what if I had a bunch of little pictures of tadpoles, and I wanted them to follow motion paths? But, since they are tadpoles, they should bend to match the bend of the path they are following?
    What should I use? I could animate a “bend” effect on each of them, but there are supposed to be a whole swarm of them, I would obviously hope for a simpler method.
    Ryan Hill replied 14 years, 4 months ago 2 Members · 2 Replies
  • Dan Fredley
    May 9, 2012 at 5:06 am
    How about just animate one in a precomp flipping it’s tail back and forth in a loop and then use it as a video sprite in Particular to create the swarm?–if you have Particular, of course.
    Another way would be to just have it “Orient along path” instead of “bending”. Still might give the effect you are going for.
    Layer>Transform>Auto-orient>Orient along path
    Dan Fredley
  • Ryan Hill
    May 9, 2012 at 5:38 pm
    I have a swimming motion in a loop, but I was hoping also to have it bend to the left or right when it’s turning left or right.
