Activity Forums Adobe After Effects Motion path and Particular
  • Motion path and Particular
    Posted by Kim Petersen on November 19, 2007 at 3:16 pm
    I have a complex illustration (consisting only of lines) made in illustrator, which I will copy into AE.
    I want to animate these lines in a “write-on” manner with particular (I want to add some turbulence later to make it more organic). My question, how can I parent the light emitter to my path imported from Illustrator?
    Thanks for any help!
    /Kim
    Kim Petersen replied 18 years, 9 months ago 2 Members · 2 Replies
  • Darby Edelen
    November 19, 2007 at 8:47 pm
    You should be able to paste the path from Illustrator directly into the position property of the light, provided you have followed the instructions in the AE help file:
    “Note: To make the data copied from Illustrator compatible with After Effects, the AICB option must be selected in the Files & Clipboard section of the Adobe Illustrator Preferences dialog box.”
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Kim Petersen
    November 19, 2007 at 10:14 pm
    But of course! Thanks Darby for the feedback.
    /Kim
